Old 12-21-2008, 12:25 PM
efnfast efnfast is offline
Originally Posted by csx4343 View Post
After 3 years I finally realized that that LESS S is Best, my 1/4 lb jar will last 4 years and I do my car every April and September. Also another method that helps is changing the fleece wraps more often (pain) to avoid residual build up. Change both wraps for each panel. When done wipe residue with 2 MICRO FIBER CLOTHS one with a little (very little) WINDEX without amonia any then use dry cloth for final luster. Nuvite also has a liquid polish as a finish coat that can be using the Micro Fiber Clothes. After all of that you will have a better job however bright sun with humitity will still annoy you, just not as much. I hope this helps a little. Have Fun and a Happy Holiday
Ya know, I think that less is more has been my problem on the final step - usually i would use a fingerprint worth of S every 3'', but when I started going 6'' I got out most of those funny marks that would travel around the panel.
