Old 12-23-2008, 06:19 PM
Robert McLinden Robert McLinden is offline
Cobra Make, Engine: 396W Kirkham KMPS036
On both my engines (302 block for Kirkham and 351 block for ERA) I had to remove the half moon shaped piece clearly shown in your second photo. This allows the use of the next outward set of holes moving the starter away from the flywheel. Make sure the starter pinion clears the flywheel also (you may have to shim it). Good luck and be careful I chewed up the ring gear in the ERA and had the pleasure of replacing it with the engine in the car (no lift).
Bob McLinden
ERA FIA 2080 SOLD
Kirkham KMPS036
