Old 12-24-2008, 09:52 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Tom Cimino View Post
Here's the answer I received from Chris Rowe at Edelbrock
Tom,
The valve locations on both heads are different, if you use the 60079 heads then you need to run pistons for a 427ci engine.
Looks like the 427 MR heads won't fit on my 390 block
Interesting, I had thought that the valve locations were the same on both heads, that both heads have the intake valve off centerline like a 390-428 head, and the exhaust valve is father from centerline like a 427 head.
And now that I think about it, I think that's exactly how I had to space the rocker arms on the shafts.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
