Old 12-24-2008, 09:26 PM
zimmy's Avatar
zimmy zimmy is offline
Cobra Make, Engine: Contemporary, 427 FE Center Oiler w/ 48 IDA Webers
Send a message via AIM to zimmy
Default Fuel leak question
I have been fighting a problem for a while and need someone's help. I have 48 IDAs on a big block with the 10 deg canted intake. Whenever I stop the car after a drive, the heat seems to percolate the fuel and I get dripping out of the accelerator pump jet. It collects in the throat and eventually leaks out of the throttle shaft onto the manifold.
I have a return line on the fuel so it should be immediately dropping pressure when the car is turned off and I have the phenolic gaskets under the carbs.
Any suggestions? Has anyone else seen this problem and can you explain it to me and the solution???
Very frustrated!
Thanks.
