Old 12-26-2008, 08:24 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Neutral
I have used the lambda sensor to tune, and with the larger air corrector the mixture gets lean at the top end. The 100 worked best and the A/F ratio stays steady up to max rpm. I started with the 220 air corrector and went all the way down to 80, but I settled for the 100 which I have now. When I put the 115 on to double check that I am not going astray with the tuning I get a lean top end.
Webers were used on smaller engines when they were popular, and the formula may hold true for them.
I do not think running webers without the chokes will work. The chokes have a distinctive shape inside to create under-pressure for the aux venturis to work.
You con go larger with up to 45mm chokes for the 48IDA.
Top end will probably be some better but driveability will suffer.
Nothing sounds better than a Cobra in a Tunnel !
