Old 12-26-2008, 05:20 PM
madmaxx madmaxx is offline
I may have found a solution to the pos wilwood two piece. Sure it would have been easy to order a billet one but hey I was bored. I remembered repairing a leaking gas tank back in the late 80's. It was dripping, I smeared some Seal All and 10 years later sold the car and the tank never leaked again. The stuff is cheap and impressive. I took my two part piece of sheet reservoir apart, washed it out. I then put a bead of Seal All on the bottom half of the o-ring and the very bottom of the top reservoir. I slid them together and tighted the clamp. Leak sealed. I also put a glob on a can of a lid, let it dry and then popped off the piece and put it in brake fluid, the brake fluid does not deteriorate the seal all. It is the only sealant I found that can seal solvents once it cures. If your bored give it a try. Remeber to put it on the bottom half that way when you slide the reservoir on it is pushing the sealant down. This ensures you do not get any in the reservoir.
