I believe that Trigo suggests 60 lbs for the torque spec on their wheel pins. And I don't think any Loctite is recommended by Trigo...Are yours the Trigo's pins that have an internal hex or the internal star? The star in the latest version. I know that overtightning them will destroy them - so if they cracked I'd bet that's what happened. . Proceed with caution here...a little research is in order I think. Are the pins snug in the wheels? (correct diameters) Did you replace them all with Trigo pins ar just a few on each wheel? Are the fronts also coming loose? Lets see what the CC braintrust knows. There is a lot of experiance here...
Edit: Vintage Wheels may indeed suggest blue loctite...check it out.
SPFWiringDiagrams@Comcast.net
