Old 12-28-2008, 06:00 AM
undy's Avatar
undy undy is offline
Originally Posted by RonNichols View Post
Dave,
Not that you're asking me, but I'll interject anyways. For the money, you can't beat the cost of the Megs' merge collector kit from Cone Engineering. I wondered how to get a slip on merge collector to work, and experimenting with a $300+ each collector not knowing if it would look or work well made me sick to even think about trying it. The megs venturi merge collector kit was less than a 1/3 of the cost and came out looking, in my mind, better than a Dynatech or Kooks. You can trim the divergent side of the collector to butt weld smoothly to the cobra pack muffler, or transition it internally.
Ronnie
Thanks Ronnie, that's a sweet setup. I need to see who I know that has a tig welder. Paying a pro shop can lead to a lot of $$ for all that detail. I have a gas mig welder myself but it'll be like doing brain surgery with a Bowie knive. I don't weld enough to make it pretty anyway. Also, with my existing 4" collector I'll have to see if I could pull the primary bundle together tight enough to fit in the new collector. A couple large hose clamps around the primary tube bundle might pull it together. Cone Engineering has some pretty good instructions on their web site too. A little investigation is in order. Thanx for the info..
Dave
