Hey David, I believe the factory used 68-9 Camaro tanks with a relocated fill tube from the back centre to the right side. We have been basically using the same space and shape but more effectively with a tank that really fills the cavity. Ally will run about $600, stainless around $850, depending on current market material prices. That is a 24.6 gallon tank set up with a sender compatible with your guage, pickups for fuel, baffled to stop sloshing, drain plug, mounting straps, guaranteed leak tested, fill tube to fit your neck, effectively a complete tank ready to install. If you want to run fuel pressure guage like a comp or SC we can do two pickups and no sender. You can see a few examples on my website if you're interested or I can convert a Camaro one for you. I have been making tanks and other parts for quite a few different breeds now including CCX, LAE, B&B, Midstates, KMP and CSX continuation and originals. Check out my website and let me know if there's any other questions I haven't covered. You can talk to me about payment options also as that's a concern with our expensive hobby. I can get going on a tank with just a deposit to cover materials if that helps.
Reason: It's all about options
