Thread: Bolt tie wire
Old 12-29-2008, 12:32 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Tell me why you need lock wire anyway.....whats wrong with a good old stainless cap bolt and a stainless spring washer for that matter. How many new cars these days use lock wire on their brake systems!! Look inside an engine how much lock wire can you find inside of there.. none just a good bolt with the correct torque... anyway thats my two bobs worth.. My cobra has stainless cap bolts from one end to the other.. They don't come loose
Cheers Mark
