Old 12-29-2008, 12:28 PM
hi-tech cobra's Avatar
hi-tech cobra hi-tech cobra is offline
Cobra Make, Engine: Hi-Tech
Default Install Blue Thunder intake
Any pointers / thoughts about the correct way to do this would be appreciated.
Hi Keith,
I posted this over on the FE forum as well. Can you give me a little guidance with this?
I'm going to pull the Edelbrock intake that came on my KC 482 and install a Blue Thunder intake (already ported to match KC stage 2 heads).
Can I reuse the intake gaskets? The engine only has dyno time. Or do I need to get new ones from KC?
Can I install the Blue Thunder using the install instructions for the Ede RPM manifold?
KC puts a nice black silicone bead around the intake. I would like to do the same. Would this stuff from Jegs work?
http://www.jegs.com/i/JEGS/555/28045/10002/-1
Thanks,
John
