Thread: tremec or bust
Old 12-29-2008, 03:57 PM
scooby snake scooby snake is offline
Cobra Make, Engine: 427 SHELBY FE PUNCHED TO 482 $16000.00
1] Before installing trans remove shipping plug in rear tailhousing. spin input shaft while trans is in neutral. It should spin freely
2] Now put trans into 1st gear again spin input it should spin although not as easy
this takes care of the stuck in gear due to shipping
3] Once installed ,while rear is in the air [supported] run engine and shift through the gears 1,2,3,4,5,4,3,2,1 back and forth a few times to help break the trans in
this breaks in the trans with no load
I work for / against Mike at Forte's Parts Connection
Call 508-875-0016 to order or for tech help
