Old 12-29-2008, 06:05 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Walter, the water outlet bolts are 5/16x18 so they can be safely torqued to around 15 lb/ft. If using an aluminum intake manifold I recommend a little anti-seize cpd. on the threads to prevent galling.
Thanks everyone for the comments. I too like the O ring housings. When they work they work well. I especially like not having to scrape off gasket material whenever I want to remove the housing. I think I have just run through a string of bad luck lately with these housings. I checked two of them and both were warped. Looks like I need to do the glass pane and sandpaper routine. In the past I have used self-stick 220 grit on a glass pane with success.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
