Old 12-30-2008, 02:32 AM
mikey mikey is offline
Default TWM Induction Vacuum source advice
Hi guys & gals
I need some advice from those who have fitted TWM induction or those that can help. I have included some photographs to help explain my questions. My manifold has an alloy plate bolted to the underside which I guess acts as a vacuum reservoir. The engine is a SB chevy (whats that hissing sound)
• Can I fit the brake vacuum take off for the servo to the larger take off at the front of the manifold.
• Can I take a vacuum take off to the vacuum gauge by using a tee piece as shown in the photograph or will this affect the sensor.
• Is it OK to plumb the PCV valve to the take off next to the sensor tee piece. I guess any engine fumes will be drawn into the cylinders under vacuum but I wish to check.
Your help would be very much appreciated.
By the way I hope you all had a great Chrismas and I wish you good luck in the New-Year.
Mike
Mikey B
