Thread: Drive Shaft
Old 12-30-2008, 02:05 PM
boxhead's Avatar
boxhead boxhead is offline
OK then, I am getting the idea that the vertical faces should be parallel and that the shaft itself needs to be balanced. Some degree of horizontal angle between the two is also needed for the universals to operate effectively.
Is that correct?
I will, of course, use Warwick's engineer as he has the experience with his car design.
Yes.
Cruising in 5th
