Old 12-30-2008, 05:26 PM
Barry_R Barry_R is offline
I didn't take "after' cut pics - but I'm sure Dave will. On this set I took them down pretty far because we were concerned about hood clearance - pretty similar to the other photos here. The important things are to avoid going right down on the bleeds, and to be certain you have at least 3/4" of clearance above the vent tubes. In this set I did not intall any steel tube extensions after trimming - that can be done afterward if you have any sign of splash out in cornering/braking - keeping the clearance requirements in mind.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
