Thread: Which Flywheel
Old 10-27-2001, 07:42 AM
Coloradocobra Coloradocobra is offline
Default flywheel
My flywheel is a McLeod unit with the correct 28oz unbalance for a 428. A lot of the original flywheels are getting pretty old and it is probably safer to go with a new one. David Kee sells these flywheels as well as the mating clutch pieces. I am running a McLeod dual friction setup which my builder claims is not as hard on flywheel surfaces as the centerforce setup. Pedal feel is reasonable with 3/4" master and McLeod hyd. throw-out brg.
If you are running a 427 you might want to ask David about flywheel weight as the faster revving 427 might respond well to a lighter flywheel. I can get you my part number if you need it.
Gary
