Old 12-31-2008, 05:27 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
What's wrong with running a vacuum gauge?
It's the second most useful gauge behind a Wideband A/F gauge.
If the area under the top plate is a common plenum for vacuum you can tap into it anywhere you like for accessories like power brakes, map sensor, vacuum gauge, but be wary of PCV plumbing, needs to be central for equal sharing.
Gary
