Old 01-01-2009, 04:29 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
As David said it could have been much worse. This is a blessing in itself because things could have gone from bad to catastrophic (I have had that happen). I am sure you are replacing bearings, oil pump, and pick up on the engine. If you have an oil cooler throw it away too. Replace anything that moved your oil because you will never be able to get all the metal debris out of your oil lines or cooler. Cheap insurance for the future life of your engine.
Clois Harlan
"Let's roll"
"Be part of Something Good
