Thread: clutch on CR's
Old 01-03-2009, 07:09 AM
patrickt patrickt is offline
Originally Posted by MaSnaka View Post
With no more oil leak I can now see what appears to be clutch fluid. 1 little drop about the size of a penny after a drive.
A drop of fresh oil and fresh brake fluid are pretty are hard to tell apart on the pavement -- and I've had small leaks of both that tracked to different locations before dropping to the ground. The only way I was able to tell what the drops were was by using UV dye. They make a different UV dye for oil and for hydaulic fluid; you can get different colors as well. Before you even think about doing repairs, put some UV dye in -- you might be surprised at the result (it will also help you pinpoint the source of the leak).
