Thread: clutch on CR's
Old 01-03-2009, 09:10 AM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
Patrickt, You are absolutly right about identifying leaks. I make assumtions and guess and check. I think the next time I have this problem I will use that UV dye. It would sure take out the guessing part of the equation. My tranny guy said brake and clutch fluid are water base in nature compared to oil and the drops on the drive way will wash away with water but the oil will stay put. I don't want to make him sound like an idiot if I quoted him wrong, but it's possible. I have an epoxy finish on the garage floor and nothing will soak into the concrete. It just sits there till you wipe it up. Even water dripping from my wifes car in the rain will build up to a point where I have to sweep it out. I am happy to report there are no wet spots under the Cobra, no oil, no hydraulic fluid, no coolant, dry as a bone....knocking on wood.
John
