  #22 (permalink)
Old 01-04-2009, 12:12 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Terry,
Right, if you go from a disc/drum to 4-way discs you will need a different M/C.
Residual valves are not "normally" used unless the M/C is BELOW the calibers. I.E. Streetrods like '34 Fords, '40 Willy's and the likes. An adjustable proportioning valve like Wildwoods IS usually needed on the Cobras.
DV
