Old 01-04-2009, 05:43 PM
brettco's Avatar
brettco brettco is offline
Cobra Make, Engine: Hi tech 427 SC
So the last coat of 3047s paint will be new? Doesn't the orignal gold finish need what you say is stuck to the back of the paint chips? If the new car used enamel the coats of paint would melt together into one paint film. If it was lacquer and someone waited long enough between lacquer coats they could seperate. You say the quicky repaint didn't stick well but it pulled the gold with it? I guess if you want to call the original substrate the original paint that makes sense but 3047 would still need new topcoat color? This is all a play on words I guess. Good luck. Brett.
