Old 01-04-2009, 05:32 PM
mikeforte mikeforte is offline
Hi J,
The T/O bearing needs at least .100" clearance to the fingers with the slave piston fully retracted. The reason it needs clearance is so when the clutch disc wears, the fingers rise and if the fingers are already in contact with the T/O bearing the clutch will slip under load causing the clutch to fail because of never fully engaging.
Call me with any questions.
Mike Forte
508 875 0016
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
