Old 01-05-2009, 06:00 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Entdoc,
here is a question
After 2000 RPM, if I change the main jet (not idle jet) from 160 to 165 , 170 will that allow me to lean out my idle circuit.
If I understand the books that I read correctly, the main jet helps with the idle circuit around 2000 rpm and carries it the rest of the way.
When I tried the a lower idle jet 55 with 100 holder (prior to the making changes to my main circuit) I still experience a lean popping condition right after 2000 rpm.
However I increased the idle jet to 60 and experienced the same problem.
When I changed the air corrector, e tube and main jet car ran great. (210, F7, 160)
Now I am looking to lean out my idle and everything below 2000 rpm.
