  #23 (permalink)
Old 01-05-2009, 08:03 AM
RedBarchetta RedBarchetta is offline
Banned
Originally Posted by Great Asp View Post
What is a good operating temp range for an FE, or a Windsor?
E
Water boils at 212. Ideally you want to achieve that temp so that moisture and any other impurities "boil off/out." That being said, oil should typically run 20-30 degrees warmer than the water (when CRUISING). So if your CRUISING water temps are running at 190, your oil should be in the 215-220 range. Race conditions are an entirely different matter.
-Dean #747
