  #33 (permalink)
Old 01-05-2009, 08:09 AM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by RedBarchetta View Post
Water boils at 212. Ideally you want to achieve that temp so that moisture and any other impurities "boil off/out." That being said, oil should typically run 20-30 degrees warmer than the water (when CRUISING). So if your CRUISING water temps are running at 190, your oil should be in the 215-220 range. Race conditions are an entirely different matter.
-Dean #747
So about 105 c. What temp would be the danger zone?
Doug
