01-05-2009, 08:09 AM
CA
Originally Posted by RedBarchetta
Water boils at 212. Ideally you want to achieve that temp so that moisture and any other impurities "boil off/out." That being said, oil should typically run 20-30 degrees warmer than the water (when CRUISING). So if your CRUISING water temps are running at 190, your oil should be in the 215-220 range. Race conditions are an entirely different matter.
-Dean #747
So about 105 c. What temp would be the danger zone?
Doug
