Old 01-07-2009, 09:14 AM
xlr8or's Avatar
xlr8or xlr8or is offline
You might try removing the pusher fans in front. They can obstruct air flow and are useless at speed anyway. Also verify the puller fan is blowing the correct direction and sucking air through the radiator. Have you burped the block? Bring the temp up a bit and loosen the temp sensor in the intake to let out any trapped air.
