Old 01-07-2009, 11:45 AM
Larry N Johnson's Avatar
Larry N Johnson Larry N Johnson is offline
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Default Studs
Originally Posted by cdnus View Post
They are supposed to be hub concentric, but mine have such a large radius on the inside that they actually do not come in contact with the hub flange.
Therefore they are centered by the studs & taper on the nuts only. Not that that is a bad thing, just perhaps not the best.
I do have 15k mi. on these this way with no problems, so for street use they are ok I guess.
Craig
I have drive at Miller Motorsport Track nearly 140 mph; no issues. Center is center. The studs can hold up 640 lb per corner pretty easy.
