Old 01-07-2009, 10:56 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Hey Rick,
I did some testing albeit a little crude with dual pusher fans. I hooked a high resolution amp meter in line to see if the amperage draw increased at a few highway speeds. My thought was if the airflow was higher than their RPM it would load the circuit and amps go up. I found the load or amp draw on the motors did not increase but dropped a small bit.
It would be easy enough on most applications to loosen set screw on fans and remove from the motor as a with and without test.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
