Old 01-08-2009, 08:06 AM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Originally Posted by WildBill1965 View Post
Part of the reason for the turkey pan being under the carb besides the ram air effect, was to keep some of the engine heat off the carb to keep fuel from boiling.
That was my intent, to reduce the heat transfered into the bowls making the duel denser,etc. But some modern thoughts about vaporization/atomization make the cold intake/hot bowl idea something to ponder. That would be easier to fab up initially than a turkey pan and might reap better benefits...at least I can compare the 2. Nice set up, by the way.
I didn't realize you were using the Carter style carbs either, you MAY be able to fit them in a pan. I'd have someone with a turkey pan measure the opening length and then measure your carbs. Because they lack the bowl length one both ends as well as the middle, it may work. I remember that 2-4 Cobra intake I used to run on a '65 fastback was for the Carters and the mount pads were placed too close for Holleys unless they were sideways.
WDZ
