Old 01-08-2009, 12:38 PM
Larry N Johnson's Avatar
Larry N Johnson Larry N Johnson is offline
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Originally Posted by KevinW View Post
Thanks guys.
I was thinking about that idea Larry, but i would still have a problem as simon's adaptors are only for the front - am I wrong?
would 15" rear and 16" front look stupid? :
cheers,
Kevin
Kevin,
Simon can do both front and rear hubs for the Jag setup. Or get Simon fronts and www.justcobras.com rear. That way you get the narrowed front track you will need; 6-pin, no adapters. Image of justcobras rear Jag hub:
Then you can order Vintage Wheels w 15" tyres mounted and balanced, so 15" tyres should not be an issue. They seem to last forever. For example, I have a set of Goodyear Eagle GTII w 6 seasons, 21,000 miles, about 50% rubber still left.
16" on one end and 15" on the other would not be the "original look". Some compromises to originality are generally made by us all. After a while, it's okay. Vintage has sharp 17" pin-drive rims, if that helps you.
Keep after it, Kevin...you'll find what you want eventually.
Regards,
