Old 01-09-2009, 07:38 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
I was looking into trying to buy one of your bodies to put on a CSX4000 frame, and was told that there would be a problem at the door sill area. I understand that you fabricate your frames and bodies to be a perfect fit to each other. I was just inquiring.
I think the problem area may be trying to install an aluminum body on a CSX4000 frame that was made for a fiberglass body. Although the main frame rails and suspension brackets may be the same, the smaller tubular frame supporting the body is different, and I think the fiberglass body 4000's have an extra tube in the door seal/jam area that the original 3000 cars, and the aluminum 4000 cars don;t have.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
