Old 01-10-2009, 11:27 AM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Now, things get interesting.
Between the red arrows, you can see a bright, shiny ring that goes all the way around the very end of the pin. That ring is where the black oxide coating has been scraped off the pin as it was tightened into the hub adapter.
That ring is the ONLY contact point where the male taper of the pin contacts the female taper of the hub adapter. Notice it does NOT make full contact.
