Old 01-10-2009, 06:47 PM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
ahhhh i get yah.
Blas, Yes, on 2734 the wipac ABS plastic headlamp cups exist and are filled with a generic sealed beam bulb from the folks at Trans-ssylvania . DL2 or whatever.
When I last saw Greg I was in the middle of upgrading my headlamps to Hella H4 carriers and a higher wattage bulb.
I used the painless harness 30815 that uses an existing headlamp socket as the trigger wires for relays to then subsequently feed the H4s. (nice setup)
http://store.summitracing.com/partde...5&autoview=sku
not 110% plug and play on the SPF but definitely worth the hassle. Example : the headlight plugs for the H4 end of the harnesses come pre-terminated ( as they should be) and inserted into the headlight plug.
--- problem, to get them through the SPF fender well grommet and into the rear of the WIPAC ABS bucket, I needed to pop the blade connectors our of their plug carriers and feed the wire through the allotted holes. (fenderwell/bucket) --then re insert the blades connectors into their ABS " plug" for the headlamp(s).
Painless leans towards using GM wire colouring on their generic stuff. so example; Tan is base headlight + , green is hi-beam + , and black is ground.
Catch you later !
Steve
everything is back together now and works FANTASTIC. I have 80/100s in there now and can give people suntans at night.
I also updated my Driving lights to a pair of Lucas LR8s (pictures on the way.)
--See you guys soon.
Steve
