Old 01-13-2009, 11:02 AM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
Undy,
I am a little confused. Why do you say that you have too much gear? 3.73 x .64 / .82 gives you an equivalent rear end ratio of 2.91 with a .82 o.d. transmission. I would think that if you are running a tire that has close to a 28 inch diameter that you should actually be pretty close. Any less gear and 5th gear will become more unusable. What size tires are you running? Are you sure you didn't get the .82 overdrive? If you can give me your tire size, RPM and speed in 5th gear I can tell you what overdrive ratio you have.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
