Old 01-13-2009, 03:31 PM
2KWIK4U's Avatar
2KWIK4U 2KWIK4U is offline
Cobra Make, Engine: Lonestar LS427, Keith Craft 496 Genesis, 649 hp, 668 ft-lb, TKO-600, Dynatek Stack EFI
Undy
I switched out the 3.70's in my LS Currie to a 3.25 with the 0.82 and its perfect. We have almost the same engine config. and 1st gear is very useful. Use a mirror and get the stamped number of the top of the rear end housing and give it to Currie for the specs of the original build. My LS supplied Currie was build with the TrueTrac carrier. If yours has this, and I believe most LS's did, it does not have any clutches internally, and when you rotate one wheel, the other will not rotate or will rotate reversely, but is still a limited slip. See this link:
http://www.eaton.com/EatonCom/Produc...trac/index.htm
Brad W.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
