Old 01-13-2009, 05:59 PM
DonB DonB is offline
Cobra Make, Engine: CMC,Ford 302
Default Drive line angle/pinion angle
I've finally got my engine,trans and a new 8.8 rearend in place and was wondering about the angles. My 8.8 measures 4.3degrees tilted up. At the output shaft on my AOD it reads 1.5 degrees tilted downward. I was told I need 3 degrees at each u-joint. This is on a CMC cobra. Does this change with the body and seats etc installed? I figured it would be easier to adjust angles while it was in the early stages.
