Old 01-13-2009, 10:27 PM
xlr8or's Avatar
xlr8or xlr8or is offline
The tunnel should be fine. Just don't let it hang below the frame rail where it can get damaged. Would hate to lose the breaks if it got hit on a bump or object going under the car.
With a solid axle you can run it back and use a flex line to the axle and split it there or split before the axle and use flex lines on each side.
