Old 01-14-2009, 01:57 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Wodahs
you may be able to just buy the yella terra manifold.... you may be able to make a scoop to go over the blower but the inlet pipe would make the scoop wide and ugly unless you could tuck the inlet down behind By the way it's DRB not DRP
Cheers Mark
