Old 01-14-2009, 02:29 AM
wodahs wodahs is offline
cant explain that ac-460
mixing up my B's and P's like that i havent been drinking , my screen is quite large and i had their web page open at the same time
now for the yella terra unit as far as i was aware only did a charger unit for the 4 valve boss motors and also used a different head unit and not the whipple , i have previously discussed supercharges with them before and after getting mine
but as for plumbing up the inlet pipes the inlet on the charger i have shown has been removed already to have a mounting for a twin 65 mill throttle body to come out alittle lower and at right angles like the boss motor instead of running up the length of the motor and we can have it angled down towards the rocker cover when re welding the t/b mount plate , throttle body has not arrived yet from state side yet to finish this
by the way i am at this stage under the belief that my 3valve motor with the charger on it isnt all that much higher that the 4valve with the plenum
