Old 01-14-2009, 01:33 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
madmaxx- lol, you're correct.
Very good safety questions, and I will try to ease your concerns.
A 4" slab with either rebar or the cattle fencing, is just fine.
Most residential or commercial foundations are strong enough to support a MaxJax™ lift. The minimum requirements is 2500-3000 PSI 4" thick concrete.
Think of it this way, if a loaded concrete truck, or like for me, having a dump truck with a full load of dirt or compost every spring, back up in my driveway and not crack the concrete. I'm not even concerned with the heavy weight of the delivery truck, with my lift in it and I'm sure he will have other products in the truck for other deliveries. The company has tested this system many ways, before marketing it.
Like I mentioned, my friend that has the mechanic shop, all of his are two post's. Now, they are the larger capacity for very heavy vehicles but again, they are two post not four.
Here are the Specifications-
Lifting Capacity: 7,000 Lbs. / 3175 Kg.
Style: Portable Two Post Lift
Overall Height: 89" / 2261 mm.
Height of Column: 64" / 1626 mm.
Typical Width (Outside of Base Plate): 105" - 125" / 2667 mm. - 3175 mm.
Arm Reach (Min.): 24" / 610 mm.
Arm Reach (Max.): 44" / 610 mm.
Min. Pad Height: 3.5" / 89 mm.
Max. Lift Height (Pad only): 45" / 1143 mm.
Max. Lift Height (With 3" Adapter): 52" / 1321 mm.
Motor: 110-220 VAC / 50-60 Hz. 1Ph.
Time of full Rise: 30-Seconds
Individual Column Weight: 300 Lbs. / 136 Kg.
Shipping Weight: 880 Lbs. / 399 Kg.
Shipping Dimensions: 14" x 64" x 40" / 356 mm. x 1626 mm. x 1016 mm.
I also want to say that I am not, a dealer. When I believe in a product, I'll voice my opinion, good or bad. I use the same forethought when buying different products for our sprint car. Proof is in the pudding.
Regards,
Kevin
