Old 01-18-2009, 08:29 PM
fasterpatrick's Avatar
fasterpatrick fasterpatrick is offline
Cobra Make, Engine: scratch build self design 4.6l DOHC
Default Setting up a ford 8.8 center section
Anyone who has worked on the aluminum IRS center section. Does this look like it will work to set up the gears.
Also if I'm only swapping in a trac-loc and new bearings, not changing gears can I be safe to assume that the pinion depth should be the same, and just use the same thickness shim with the new bearing?
Patrick
http://www.clubcobra.com/photopost/s...0&ppuser=23754
Well, it occurs to me that perhaps not all of the modifications I made are technically 'street legal'
Nothing good ever happened after this statement;
Hey Moe watch this!
