Old 01-19-2009, 04:21 AM
undy's Avatar
undy undy is offline
As I said, do the simple resistance check on your MSD ignition module. (400 to 1300 Ohms) is the correct range. The ignition module does not necessarily fail catastrophically. It failed on mine intermittently, duplicating the same symptoms you have. I did a web search and it's a v-e-r-y common failure.
Dave
