Thread: 44 IDF's
Old 01-26-2009, 03:15 AM
68gt500's Avatar
68gt500 68gt500 is offline
Cobra Make, Engine: Sorry "just" a 68 Shelby GT500
Send a message via Yahoo to 68gt500
Originally Posted by albanycobra View Post
Also something else I noticed was that some of the carbs you can put your hand on the ram tube and the engine will stall, others you can leave your hand on them and all that happens is loud popping noise in exhaust.....anyone want some cheap webers????
Ahhh, you are not about to give up - are you?
Restricting the flow by hand is like doing the "manual synchrometer" test ...
Can you tell if the amount of air flowing thru the live & dead is the same?
When you put your hand over the intake, you are actually richening up that cylinder. This over rich mixturte will not burn in the cylinder, but will in the exhaust. That is the popping you are hearing.
It would seem to me that the "dead" ones are not flowing enough air. You need to open those throttle plates a little further.
You should have or borrow a synchrometer, it will let you set the airflow of each carb, so you have equal flow thru all of them.
Mike
68 GT 500
(Germany)
