Old 01-28-2009, 08:49 AM
Larry N Johnson's Avatar
Larry N Johnson Larry N Johnson is offline
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
Default Trigo 60 degrees bevel
Originally Posted by David Kirkham View Post
Paul,
You will certainly have to run 60 degree pins with 60 degree hub adapters. Alternatively, you can take your 60 degree hub adapters and have them machined to 90 degrees relatively easily. An easier way yet it to just tell me you want 60 degree pins and we will make them for you. But, from all I have seen, I would be careful and make sure your hubs are indeed 60 degrees. If you have any doubt, I'd be happy to check them for you.
David
One small detail
It appears that Trigo switched to 60 degree bevel around 2003 or 4 possibly. So be careful to measure your bevel. Kirkham may have to make both 60 degree and 90 degree to satisfy the market. My info source is very reliable, plus PaulProe said
The pins and adapters both are machined to a 60 degree taper, not the 76-79 that David found. I am estimating the wheels to be around 5 yrs old. I bought them used so I can't verify their source or production date.
Bob Lacey,
Your definitive post is very helpful; thank you.
Regards and Happy Pin Driving to all!
LNJ
