Old 01-28-2009, 08:03 AM
767Jockey's Avatar
767Jockey 767Jockey is offline
Default Fuel line sizing question
It's time to run the fuel line in my FE equipped older Contemporary that I'm restoring from the frame rails up, and I'm not sure what size fuel line to run. I have the sending unit / pickup out of the tank and I'll have the pickup line changed out to match the size fuel line that I end up running. The engine is a 600+ HP 482" sideoiler, with a single 900 CFM Quickfuel carb. I'm running two Facet blue dot electric pumps, each has 3/8" fittings. It's easy to just go with 1/2" line and play it safe, but it's bulky and more difficult to work with, and in such a small car it gets tight in some places. Do I need the 1/2" line? Does it even make sense to deal with the 1/2" line with the pumps only having 3/8" in and out fittings? Also, is there any reason to run a mechanical pump as well? If so does anyone have a recommendation on a mechanical pump that will have the correct size fittings? Thanks.
