Old 01-30-2009, 12:20 PM
cobrarkc's Avatar
cobrarkc cobrarkc is offline
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
[quote=Streetwize;915156]To compare what you can build either motor at 427", a stroker smallblock wins hands-down.
2 words....Modern Technology.
Take a motorsports block and put on a set of CNC'ed CHI heads and at 427", there's no way an FE can even come close in terms of horsepower. The last few EngineMasters motors have been small blocks with CHI heads that can flow close to 400cfm or enough for 800hp.
You have to compare Apples, cube for cube, aluminum block/head to the same. On paper and with a lot of $$$ you can build an all-aluminum FE that can make awesome power but at 427 cubes it won't make the power or torque of a 427 Smallblock with an 1800G bobweight. Since NASCAR went to 358" in the mid 70's the vast majority of high dollar technology was applied to improving the small block platforms of the big 3. And once the 5.0 hit the streets in the 1980's it became the 55 chevy of this generation and small block technology for very stout street use grew leaps and bounds while the 352-428 FE platform was (sad to say) ignored. The other reason the FE was not furrther developed was the packaging, 428's in mid-late 60's Mustangs were tightly packages and VERY NOSE HEAVY....once the boss 351 hit the street it became to motor of choice and today the Cleveland/Windsor hybrid with race blocks capable of supporting over 470 cubes are now the normally aspirated powerplant of choice.
The FE is great for the purist approach and I admire the ones that build a true replica that honor the originals; but the in line/narrow angle wedge head and horizontal runner angles just can't compete with a canted valve, raidsed port NASCAR Technology modern head in terms of breathing, and breathing means more power and RPM potential. "
You know most people would have to agree with you about modern technology and the canted valve heads but I'll bet 90% of the people that brag about their small blocks are running in line/ narrow angle windsor heads with that same old technology of the FE head.
Cobrarich
