Old 01-30-2009, 04:43 PM
undy's Avatar
undy undy is offline
coneeng, undy & Ron,
Can you guys supply me with all the parts & numbers for building the side pipes from the collector to exhaust tip ?
I need to get all of it ordered soon but I'm feeling so sick, my brain does not want to function. my buddy Chad said he will weld them up.
Three inch muffler, Venturi cones ect.....
Same size of yours Ron.
Undy, when you have time, please send me all the info with yours and pics if you have them yet.
Goin back to bed.
Thanks,
You got the crud Kevin?
Starting with the turn downs/tips, It's Classic Chambered part# 35-Tip
Then to the 26" bodied, packed muffler, CC part# 3026-COBRA-P
http://www.classicchambered.com/classic/products.html
The last piece is the merge collector kit, 2" primaries w/a 3" outlet Cone Engineering part# CL4-200-3-MS.
http://www.coneeng.com/pdf/4-1%20Collector%20Kits.pdf
You just pitch out the cone, you won't need it. The outlet of the merge collector will be welded directly to your muffler inlet, no room or need at all for the cone. I talked to Cone Eng and this was the recommended way for a 3" ID muffler.
If you're building your J pipes too then you'll want to by their primary alignment tool, CE part# TO-CA4-200200
http://www.coneeng.com/pdf/Collector...ents%20PDF.pdf
I already had 2" primary J pipes so I didn't need to build them. I reused them. Are yours 2"?
Dave
